Old 09-22-2014, 04:07 PM
Paintwerks Paintwerks is offline
Cobra Make, Engine: Pace 427SC. LSA Supercharged with 6sp TR-6060 trans.
As above, if you want a near-complete roller, the kits mentioned above are great.
But if you still want to build a Cobra, look at importing an Absolute Pace 427SC from Australia. The kit is built pretty much as an 'assembler kit'. Even the wiring harness is plug and play. All brand new (no reclaimed or used parts are employed). It uses a full aircraft grade aluminum chassis that can comfortably fit a 6'5" driver and a correct shape, carbon composite body with a fantastically high quality gelcoat finish that many people mistakenly believe is painted. Pace have developed a LHD version of the car too.
It uses off the shelf GM components so you can drop in a LS3 or LSA supercharged (what I'm personally doing), but it's also able to use a 427FE or Coyote if you desire the Ford heritage.
Plus the exchange rate is in your favour.
I looked at FFR on several occasions over 12 years and it was clear to me (no offense to the FFR owners) that the Pace 427SC was by far the superior kit. So that's why I bought one myself.
www.paintwerks.com.au
