Old 09-25-2014, 11:49 AM
Cashburn's Avatar
Cashburn Cashburn is offline
Backdraft Racing Dealer
Originally Posted by jimbo01 View Post
Kobura
I am not sure what you mean by "stock" gauges. They normally would be Autometer, VDO, or Smith's. Depending on what Backdraft installed in the build this should be the case. If the speedo and tach are Autometer then most likely the others are the same. It's possible that your gauges do not need the additional ground that the VDO gauges need. Read your gauge instillation instructions for this info. You can find this on line by checking the manufacturers instructions.
There was a year of production that Backdraft installed their own gauges. There were issues so the Speedo and Tach on the cars we delivered received a matching Autometer style gauge in those places. These gauges had LEDs instead of bulbs and might be the reason the grounding was not an issue, since you are reporting the issue is when the lights are on.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
