Thread: TKO Upgrade
Old 09-27-2014, 01:18 PM
Lightingrod's Avatar
Lightingrod Lightingrod is offline
Cobra Make, Engine: Classic 427, I purchased it May 2005, the kit was bought in 1991. I'm not sure when it was completed! Installed GMPP Connect & Cruise 376/525 with T-56 S/M 3.55 gears about 2 years ago! 1/4 miles is with old setup!
Originally Posted by RET_COP View Post
Tko 600RR steeda tri ax with a nice steeda shifter, in the rear position. 3.27 rear im on the fence about switching to 3.55. Trans has notchy shifting but does get better. After 500 miles it showed improvement. Without some work its not the best powershifting trans. I have a cable set up and i found out through experience when i slightly pre loaded the throughout bearing i had a big improvement in power shifting and speed shifting. Thats cable mind you.
What shifter position; rear-center-front?
Al
I want to do right, Just not right NOW!
