Old 09-27-2014, 02:03 PM
Cobra01 Cobra01 is offline
Cobra Make, Engine: Absolute Pace 427 SC
Hi Simon
A nice thing that I should have done when was putting in the insulation was to trim the insulation material 15 MM narrower than the stainless panel then you would be able to see that there is an Aluminium Chassis between the Stainless Panels.
Another thing to consider is to seal the edges of the insulation material with heat resistant Silastic so it won't fray and run .
Also remove the protective material from around the bolt holes in the stainless panels before you fit them to the engine bay.
This will stop the being little bits of the plastic covering poking out from under the heads of the Stainless Button Head bolts when you fix them to the bulkhead.
That's all for now and well done.
Brad
There is nothing better than a cold beer
