Old 09-29-2014, 10:53 AM
bliss's Avatar
bliss bliss is offline
Yes, these are two fuses that are separate from the fuse blocks in the engine compartment. These two fast-blow fuses are located on the steering column, right above where your knees are when you are driving. First, examine them, then if they look like they're ok (meaning one is not blackened with an obviously blown filament), then pull them both out and switch them, then put them back in. See if that makes any changes. And while you're doing that, with the ignition key on, put your foot on the brakes and tell me if both, or only one of the brake lights is coming on.
What ERA number is your car? Perhaps the really early ones didn't have the fuses. I'll check the schematic for your car number and see.
EDIT -- It looks like they put the fuses in around car 335.
Thanks - mine ERA is 098 - very early - so, no separate fuses?
