Old 10-01-2014, 11:45 AM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by 66gtk View Post
Here's a photo of the "other" side. As you can see there are a handful of washers that help to space out the striker so it aligns. I assumed that was done during fine tuning of the assembly - suggesting that the wedge MUST be able to be removed and put back in. If it was "cast", why would there be adjust ability via washers.
That's what I thought also. Matter of fact, I think there is a passage in the ERA manual about making adjustments to the striker by separating that piece and moving washers from front to rear or vice-versa(?) to fine tune the latch. On second though, I guess it's the end at the nut that may be threaded. It looks like it has some striations like a wheel stud. You might try epoxing it with some good 2-part epoxy adhesive. Not sure if that would hold up very long or not.
ERA 782 Running
