Old 10-01-2014, 04:08 PM
Rick Parker's Avatar
Contact Cobra Restorers for the ferruls. The Lift A Dots are used a lot in Boat upholstery and covers. They are available with a self threading screw stud about 1/2" long or a machine screw stud that requires a nut. There is also a fiber washer that is available from Cobra Restorers that fits between the painted surface and the Lift A Dot Post. Ths ferrulls are smooth machined and need to be roughed up, then they will accept epoxy adhesive in the holes you drill in the fiberglass. You will really Pucker when you begin drilling holes. Measure carefully is the phrase of the day.
Rick
