Old 04-14-2002, 06:12 PM
jdean's Avatar
jdean jdean is offline
Default Hey David in Kountze
Glad to see you have it running. What colors are you deciding between?
You might have mentioned some specs about your car in previous posts, but i am curious what rear end ratio you are using. I am also doing a longer-than-it-oughta-take build since I keep changing my mind on things during the build. I am using a C6 auto as well, and just recently went to a 3.27 rear instead of the 3.08s I had. This is because I am going with taller tire/wheel combo than i planned originally, so the final ratio will be close.
All this changing eats up time and money, and a lot of it only makes subtle differences. Is it just me?
John
