Old 10-02-2014, 08:59 PM
Double Venom's Avatar
Double Venom Double Venom is offline
"Lift a Dot" is the correct fitting- found all over the internet. It's the "studs" that are tricky. They too can be found on the internet. Stand bye on the "studs" give me until tomorrow I might have some??
If you are doing both do the Top first! Once you have the studs mounted for the top THEN lay out the Tonneau and then match the lift a Dots to the studs already in place.
Hint: Buy quality pins! The cheap ones will snap off in the fiberglass when screwing them in....a real night mare
Hint #2: Dap each pin with red locktite as your screwing them in. Adds a little lubricant plus when the locktite dries it will lock the pins in tight-Lasts for years.
