Old 10-09-2014, 05:29 PM
DaveW's Avatar
DaveW DaveW is offline
Cobra Make, Engine: Classic Revival CR3514, LS3, Dual Quads, Holley Dominator EFI, TR6060, VE 3.7 LSD, AP Racing Brakes, 17x8 & 10 Custom Dragway Billet Wheels.
Classic Revival suggested wheel specs for the round tube are as follows,
Front;
8" Rim. (9" total width including Beads)
Backspace = 6"
Front space = 3"
Offset = ET38, or 1.5" towards outside of the wheel from the centerline.
Camber = 1.0 to 1.25 deg negative
Caster = 6.0 to 8.0 deg positive
Toe In (total) = 2.5 to 3.0 mm
Rear;
10" Rim. (11" total width including Beads)
Backspace = 6.5"
Front space = 4.5"
Offset = ET25 or 1.0" towards outside of the wheel from the centerline.
Camber = 0.75 deg negative
Toe In (total) = 1.0 to 2.0 mm
Ground height is measured under the main frame rails and is designed at 120mm
I don't have any details for the square tube.
http://cobra-cr3514.blogspot.com/
