Old 10-10-2014, 06:03 AM
Aussie Mike's Avatar
Aussie Mike Aussie Mike is offline
Hi Dave,
I measured the rotor PCD. They are as close to 220.5mm as I can see on a steel rule. The ID for the lugs is 205mm so they fit over the hat just fine. The rotor is bang on 330mm diameter and the same thickness as the territory rotor.
Finished off the rear brakes tonight. Trial fitted the other hat and thought I'd snap a pic of how neat it fits into the Ford backing plate after machining. Very pleased with that.
Sand blasted the hats and the rotors to remove old paint and rust. The hats got a coat of high temp black paint to tie in with the black anodized hats on the front.
Love this view with 24" of rubber on the back.
Start on the front suspension tomorrow.
Mike Murphy
Melbourne Australia
