Old 10-11-2014, 10:27 AM
Eljaro's Avatar
Eljaro Eljaro is offline
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
Default Front springs now 250lbs
Ended up getting new 250 lb springs. The old springs that came out were one shorter (about 1/2 inch) than the other. Probably from a hard landing in a ditch. New springs on old Spax Gas shocks are much better now, ride more comfortable without bumps trying to steer the car.
Will change the rear springs now. Will get one set of 250lb springs and replace ona pair and see. If it is not enough I can replace the other pair.
Nothing sounds better than a Cobra in a Tunnel !
