Old 10-14-2014, 05:07 AM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by davids2toys View Post
I don't remember because it was over a year ago. I cant get it on the lift for a while because my mustang is dead on it at the moment. It did go thru something that was a PITA, but I do not remember if it was the parking brake or not. When do you need to know by? I will be doing a bunch of work on it this winter and I can give you a definite answer as soon as I get it back on the lift
David - no hurry. My speedometer is doing better with the work I did on it. I will probably try to pull the plastic gear this winter to check it and may try to pull it from underneath first. If that doesn't work for me then nothing ventured, nothing gained - I'll pull the tunnel out.
ERA 782 Running
