Old 10-15-2014, 09:03 PM
GT350Mike's Avatar
GT350Mike GT350Mike is offline
Cobra Make, Engine: CSX6363
The easiest way I've found to center and hold the oil pump drive shaft in place is to pack the hole with grease. If the distributor doesn't drop in place, rotate the oil pump shaft just a little so it will be in alignment with the socket end of the distributor.
