Old 04-15-2002, 10:52 AM
427sharpe's Avatar
427sharpe 427sharpe is offline
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
AHA MR Watson! A new part to the puzzle! Are you using a steel gas tank?? If you have a pinhole in the bottom and no dent outside, it is rusting inside. Rust that got sucked into your fuel system and may have eaten your fuel pump and/or clogged your fuel filter.........you may have found your problem! While you have your tank out, check the fuel pump for flow, and replace the filter no matter what. You can flush the lines with an aerosol can of carb cleaner and an air compressor...just flush the LINES, not the carb or fi unit! This one has me intrigued, so be sure to post what happens!
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
