Old 10-20-2014, 09:43 AM
Rick Parker's Avatar
The Granada rotors are used because the bearing sizes are similar to Mustang II. When installed with the stock Mustang II lower control arms, the rotors are very close to the lower ball joint, if necessary grind for clearance. I think the rotors themselves increase the track witdthy a small amount. The knock off adapters alone add 3/8" width per side to the track (not including any + or - wheel offset. Removal of 3/8" (safely) off the wheel pad will help. But as I said befor the scrub radius cannot be overcome.
Rick
