Old 10-21-2014, 10:40 AM
Car Nut Car Nut is offline
Originally Posted by CHRIS POTTER View Post
If the temp is correct, how about a new thermostat? If the 180 is still too cool. try a 195.
I agree.
I'm sure I'll get a little heat on this but, 180 degrees is really a little low. Low engine temperature isn't good for good combustion, fuel economy or maximum power.
Optimum engine oil temperature should be 220 degrees. Below this it also doesn't allow moisture in your crankcase to evaporate as quickly, fouling your oil more quickly. Nascar engines intentionally run at 220 or more because they make more power. Newer cars all run above 200 as normal.
200 is a better temperature to run at. Change to a 195 degree stat and forget the tape.
_____________________
