Old 10-21-2014, 10:00 PM
Donunder's Avatar
Donunder Donunder is offline
Originally Posted by PeterAllen View Post
Don, you need to be referred to an ophthalmic surgeon to see if your other eye can be opened!
The Cobra has not locked up as there would be tyre smoke coming off the rear tyre. I think it is very obvious to any fair minded person the Cobra has run out of brakes in a desperate attempt to keep up with a 250 GTO in front. As a result of the failing brakes the Cobra has got out of shape and tapped the rear of the GTO causing the GTO to spin - see smoke in front of the Cobra.
PS. If you don't know an ophthalmic surgeon I can refer you to mine!
Of course Peter -- why didn't I see that?
Oh that's right -- hence the offer to share the services of your opthalmic chappie, who obviously will have his work cut out removing the 250 GTO images from your corneas.
Don.
