Thread: Engine swap
Old 10-22-2014, 04:52 PM
wrench87 wrench87 is offline
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
I went from a 342 small block to a 445fe big block, it is not that big of a deal.
FFR sells a fe motormount kit that just bolts to the original pads, you have to purchase the big block headers, I had to shorten my drive shaft.
I originally had a fuel injected car I kept the same fuel pump in my fuel cell and installed a return style regulator and a 750 quick fuel carb, I already had 600 lb springs front and rear so i was already set up for the extra weight.
The tranny mount is the same if you have a mkIII or newer there are different holes for the tranny mount to bolt to as the motor will not sit in the same spot.
factory five mk III roadster, 445 fe stroker
