Old 10-23-2014, 04:34 PM
patrickt patrickt is offline
They all match up. I even use a micrometer to check the diameter of the body. It's like they only have the equivalent of only one filiment. Hopefully superbrightleds will have a solution.
Just for test purposes, put the LED bulbs in the front turn signal lights and see if your running lights come on normally and you turn signal lights behave normally while the LEDs are up there.
