Old 10-24-2014, 10:25 AM
Tommy's Avatar
Tommy Tommy is offline
If you know what resistance the sending unit should provide (e.g., 0-30 ohms), disconnect the wires at the sender and test the resistance across the two posts with a multimeter. If it reads about what it should for that amount of gas, then the problem is either the gauge or the wiring between the gauge and the tank. Otherwise, its the sender.
Tommy
Previously owned EM Cobra
