Old 10-25-2014, 05:03 AM
Shootnride's Avatar
Shootnride Shootnride is offline
Cobra Make, Engine: Superformance, 427SO
You should be able to remove all connections by hand. Reach under the dash and unscrew the knurled retaining nut holding the speedometer cable into the speedometer. (you may have to use a small pair of channel lock pliers to loosen this nut). Pull out the speedometer cable. Pull the light bulb out the back of the speedometer. There are two knurled nuts that hold the speedometer into the dash via a U-shaped clamp. Unscrew the two knurled nuts, pull off the U-shaped clamp and pull the speedometer out the front of the dash.
Hope this helps
Ted
