10-26-2014, 02:26 PM
AR
Sorry you lost your Dad.
The 385 series is heavy in all iron - it should track straight like an arrow. If you use it you might want to think about at least an aluminum intake and preferably aluminum heads. The crank-mounted power steering pump sounds odd but who knows? The 4.6 modular motor would reduce weight by somewhere around 200 lbs from the 460. You will have to research what has to be done to adapt motor mounts.
Lots of good help on this forum so welcome and good luck.
