Thread: Fe 390
Old 04-15-2002, 04:44 PM
Hi Geary Car looks great. What compression ratio are you running? Are you going with the twin paxton set up? I hope you have a large hood to clear the blowers. Run RICH, Watch the timing. Get a MSD boost retard module. Run 1/2 inch line with a good fuel pump to keep your motor happy. Which twin blower car was it, CSX3015 or CSX3303. I went to a dyno, Second Street in PA. cost 600.00$ and was worth every dollar. If you are running more than 6 lbs of boost you might want to go to water injection. I am looking at Carroll Superchargeing in N.J. They use a mist of water to help. The system is adjustable, controlled by boost and volume. I think it cost $1K Check it out. BOOST RULES. Good luck with your car. See you at Carisle in May? Rick Lake
