10-28-2014, 07:31 AM
Ca
Cobra Make, Engine: Superformance, 427SO
Originally Posted by blykins
Clois,
Let's do it this way....
Here's how I would narrow it down:
If you have out of the box heads, I use a custom Bullet solid flat tappet cam, 240/246 @ .050", .600" lift, 108LSA on a 104 ICL that my customers love....sounds good, pulls hard at any rpm.
If you have ported heads, the Comp Cams 282S is only beat by a custom Comp Cams cam, with similar to the same specs, but more exhaust duration.
Brent,
Could you elaborate a little on the matching of these cams with the heads. It seems counter intuitive to me to match the 282S cam with less duration and lift to the ported heads.
Thank you,
Ted
