Old 10-28-2014, 08:51 AM
lippy lippy is offline
I'm going to use acetone to clean the surfaces this time and maybe try Right Stuff between the top gasket and block, and bottom gasket and pan. I was looking at the instructions for Right Stuff and it says everything needs to be put together and torqued in 5 min. Considering there is a windage tray, oil pickup, and about 20 bolts and studs to assemble, how is it even remotely possible to get everything torqued in 5 min? How do you use this stuff when there is a lot to assemble?
