Old 10-28-2014, 09:08 AM
Shootnride's Avatar
Shootnride Shootnride is offline
Cobra Make, Engine: Superformance, 427SO
Hi Ted,
A well flowing head (read ported, more efficient) will require less camshaft to get to the same point as a poorly performing head. You can picture this in your mind, if you think about for a given valve event, a better flowing head will pack more in, at a higher velocity. It makes the cam's job easier.
Brent,
Thanks for taking the time to explain. It does make sense, especially when you stated "to get to the same point". Could I assume that as a general rule that matching the longer duration/higher lift cam with the ported heads would likely get beyond that "same point" in terms of HP/torque gains ?
Thanks again,
Ted
