FE block, studs/nuts, Canton pan with windage tray. Use Right Stuff for everything. Two Canton gaskets. First one between block and tray, lightly bolt on tray to set sealant overnight. Next day use second gasket sealed both sides for the pan and final bolt on. Everything now dry and tight.
The older I get, the faster I was.
