Old 10-28-2014, 08:13 PM
Tim7139's Avatar
Tim7139 Tim7139 is offline
Cobra Make, Engine: Superformance #2660, FE-406
FE block, studs/nuts, Canton pan with windage tray. Use Right Stuff for everything. Two Canton gaskets. First one between block and tray, lightly bolt on tray to set sealant overnight. Next day use second gasket sealed both sides for the pan and final bolt on. Everything now dry and tight.
The older I get, the faster I was.
