Originally Posted by Rjscharer
Backdraft recommends that you use synthetic oil after you have 1,000 miles on your car.
It is dependent on the engine. Once you know what your engine is then go with what the engine builder/manufacturer says, NOT with what Backdraft says.
Can someone tell me why this is the case?
See response from madmaxx.
Also,how many quarts are needed when changing oil and filter?
Much thanks
No one can tell you what type of
oil, what type of filter or how much oil without you first providing what your engine setup is (stock 5.0 pan, dry sump, etc, etc. Once you know what your engine setup is then go with what the engine builder says, NOT with what Backdraft says.
Kevin....
