Old 11-01-2014, 10:40 PM
1 TUF AC's Avatar
1 TUF AC 1 TUF AC is offline
Cobra Make, Engine: Harrison, LS1 stack injection
[quote=1 TUF AC;1324507]
Originally Posted by Krait View Post
3.9 with a T56 & LS2 2nd gear starts are fairly easy. Sits comfortably in 6th on the highway.
Wish I had it here in Dubai, no hills and 140k speed limit [/QU
mine takes off in second pretty easy too. Especially when I'm just cruising around town are normally take off in second. I've tried doing some hard launches in second and I think it gives me a better 0 to 100km time but you have to ride the clutch a fair bit more to take off cleanly. I'm pretty sure the ratios I posted are right because on my engineer certificate it says I have a t 56 out of a VX ss Commodore and a R 32 GTR differential which came out from factory with 4.11 unless someone has changed that ratio on me. But tomorrow I might go for a drive and make sure the ratios and speeds are correct. I know my speedo is not out I checked that with the GPS the other day. But according to the calculator it says I do 101km in in second gear but when I drive it to speedo is a bit slow to react so it's hard to tell if I have got 100km out of second because by the time that happens I am bouncing on the limiter and I need to change to third. if sixth gear was a 0.68 ratio 3.7 would be perfect. I am still very happy with the car performance especially when you're driving through the mountain areas it's so much fun. But always thinking of different ways to improve the car even further.
I went for a dirive today and I think found out why I couldn't get 100km out of second gear. It looks to me that my tacto is out buy at least 500rpm. Because the calculator say I should be reving 2000rpm @ 60kph in 4th gear but I am reving 2500rpm. normally I don't rev over 6000rpm but today i rev it to 7000rpm but the tuner sad he set the limiter to 6300rpm. And the gps says i did 100km out second so I'm pretty sure my tacto is out or my limiter is off and I have 4.3 diff gears. It definitely went a lot better when rev it That little bit more. i have a vdo tacto maybe it needs to be reclabraded or something. I might go past the tuners and get them to plug the laptop in to see if the revs Maching up with the tacto. At idle my car sits at 1100prm but it doesn't sound like it idling that fast. I am 90% sure my tacto is out but it could be something else.
