Old 11-06-2014, 11:33 AM
motordean's Avatar
motordean motordean is offline
Cobra Make, Engine: Superformance with Roush 427 R
Simple solutions I used to use for my concours trailered show car(s):
For garage space prep
1: 10X20 HD plastic tarp
2: 2-4X8 sheets of 1/2" plywood
3: 4 scrap pieces of carpet
4: Decent (soft) car cover
Place tarp on floor to prevent ground moisture from wicking up from the concrete/dirt floor. Place 2 sheets of plywood on top of the tarp, scrap carpet where the tires will be. Do your maintenance on the car (ask if you are not certain), park it on the prepped storage spot, remove or disconnect the battery (a quality trickle charger will do if you do not want to remove the battery from the car). Throw the cover on (after cleaning the car), and forget about it until spring.
Yes, it is that simple.
Bill S.
Perfect suggestion..... OR, just drive it once a week!
