Old 11-07-2014, 03:53 PM
Double Venom's Avatar
Double Venom Double Venom is offline
Masnaka,
Depending on your MC, although I've done both ways with little or no known problems. How ever if you are using the Corvette 7" Booster (actually made for 4 way discs) really works well.
Slotted and Drilled: Baer and Wilwood both advised us to never use "Drilled" rotors as each hole acts as a heat sink and can, (and will crack like a heated marble dropped into water ) Two road courses and I had to junk a brand new set of rotors.
