Old 11-07-2014, 09:24 PM
Ohio Ken Ohio Ken is offline
Cobra Make, Engine: Classic427 351w
Originally Posted by Wisconsin_Snake View Post
When getting the kit, be aware if it moves your wheels out or not..
Also, can someone chime in if the existing mustang booster/master will work fine with the larger calipers?
Otherwise going the Wilwood route may not be that bad IF you can retain the existing master/booster.
John,
I will definitely watch for the right kit to avoid offset issue. The peddle angle you spoke of earlier... Is the longer one in your photos for non booster assist? I would like to swap out MC for one with a power booster.... Would a say 1994 mustang master with booster work?
