Old 11-09-2014, 10:35 PM
PeterAllen's Avatar
PeterAllen PeterAllen is offline
Cobra Make, Engine: Puckett 250 GTO - LS1
Ben. I was able to inspect two jets. Neither had the rubber spacer but the plain shank was 5mm in length. The threaded portion was 15mm, giving a total length of 20mm.
Both jets were a dull grey finish, probably a diecast alloy. They did have wing-nuts on the threads and importantly, the thread was very coarse, like a coach bolt thread, so you would need to make sure you get the appropriate nuts with the jets. I'll probably drop back tomorrow (pension day) and pick them up.
He's always expensive (in this case $20 each, second-hand) but he always has every Jag bit.
