Old 11-11-2014, 03:12 AM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by 601HP View Post
Dan,
The barbs on my log are 3/8" diameter, just to let you know they exist. I believe mine came from Carl's Ford Parts. When I had the tail end -4 male fitting welded on for connection to a fuel pressure gauge, the original finish became nasty looking from the heat. I powder coated it to the current finish.
Thank you for the compliments on the engine! If I keep staring at it, it may end up in the family room instead of the car.
David
Ah - 3/8 inch barbs and fuel line sound a bit better for feeding those two carbs. Is the repro set up from the pump also 3/8 inch or is it up-sized?
It is a great looking engine.
ERA 782 Running
