Thread: Clutch BS
Old 11-11-2014, 12:28 PM
rodneym's Avatar
rodneym rodneym is offline
Full Blown Member
Premier Contributor
Rick,
The arm is not bottoming out when pushed. I wasn't clear.
When the clutch is engaged (pedal released-I hope I'm using that term correctly), the clutch arm has about 3/8" free play between hitting the rear most part of the bell housing and where the T/O touched the fingers. Is that what the spring return is for? To make sure you're off the T/O bearing? Seems like most don't use them???
How was my .022-.025" of pressure plate seperation?
Thanks
rodneym
