Old 11-12-2014, 05:54 AM
blykins blykins is offline
Rub,
Cams were a lot less aggressive back in the day. The valve spring pressures back then were basically the spring pressures that I'm using now, without the inners.
There's also a general disagreement as to why flat tappet cams fail these days....metallurgy, oils, lobe aggression, spring pressure, etc. I don't do a lot of these, but when I do, I have all my ducks in a row: make sure the lifters all rotate, run Brad Penn break-in oil, take inner springs out, and I usually run a Bullet cam since they have more taper in their lobes, which helps the lifters spin. I also run the Crower EDM lifters as well, as they have a direct oiling hole that keeps the lobe wet.
Cobraboy, I didn't have any issue until a few weeks ago when I updated by Photobucket app on my iPhone. I snap all my pictures with my phone then upload it directly through the app. The new version of the app just plain stinks. I'm looking for something different.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
