Old 11-14-2014, 01:46 PM
750hp's Avatar
750hp 750hp is offline
Default Can you use Superformance (WAW) wheels on a 4.75" PCD car?
Sorry if this is a painfully simple question...
If the more recent Superformance/Wheelcraft wheels are to suit 4.5" PCD locating pins, but I have a Contemporary with 4.75" PCD, can I use dual pattern Trigo hub adapters to make it work?
I'm not sure if the 4.75" pattern can be used to locate the adaptor to the hub, then use the 4.5" pattern to locate the pins to the wheel.
I'm also struggling to see what the respective backspacing measurements are recommended for both Superformance and Contemporary, but I'll cross that bridge if I get past the PCD question.
Thanks!
Craig
