  #22 (permalink)
Old 11-15-2014, 03:40 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by Blas View Post
You have the standard Amp Meter Right?
Switch the wires on the back of the Amp Meter should move negative when fans come on. Disconnect battery when making the wire switch.
And THEN if it still averages more negative, you do have an inadequate charging system versus the demands you are placing on it.
Gary
