Old 11-15-2014, 05:06 AM
joyridin''s Avatar
joyridin' joyridin' is offline
Default Question for guys running LS engine
I figured I would try posting here since a vast number of you run LS engines.
I currently have a SBC with a Lakewood blow proof housing mated to a T56. Between the T56 and bellhousing, there is an adapter that allows you to use the original lever style throwout bearing.
Is there a bellhousing or a way that I can install an LS engine that will still allow me to use the current lever style throwout bearing arm? I prefer not to use the new style throwout bearing that is mounted to the trans.
