Old 11-17-2014, 05:57 PM
joyridin''s Avatar
joyridin' joyridin' is offline
Just a suggestion, but you may want to rethink using that rear end. The 94 and newer 8.8's were wider than the 93 and earlier due to the ring on the axle for the anti-lock brakes. This means the rims will have to be offset further out. You can put the earlier axles in, but then you would have to ge with drum brakes. To keep the disks, you need the narrower axles out of a Ranger and new offset caliper mounts from NorthRaceCars.
