Brian:
That is typically not a problem. In theory the diaphrapm used on the IDF is better for leakage control than the piston type on the IDA but the piston type is rarely a problem. What kind of problems are you experiencing?
Control of the spray can be altered by a couple of factors. The stroke of the pump is one; If the pump jet is small the delivery will be longer than if the pump is large; a heavier spring will will increase the rate of discharge for a given size of pump jet (jet meaning the discharge nozzle in the carb bore); and, finally, the bypass or exhaust valve size (sits in the bottom of the float chamber). This allows fuel to return to the float chamber from the pump, the rate depending on the size of the hole in the bypass valve--by a larger proportion when the spring is soft, to a lesser extent with a heavy spring.
The bypass valve is most critical when a stumble occurs at mid range. Enzo taught me that early on. A lot of people think it is related to jetting but what happens is that, often times, the stumble is due to a too rich shot--which for many seems like a lean condition. Putting in a 55 bypass valve will often cure the problem. Aggie 427 called me with this problem a month or so ago and a change in the bypass valve, which created a smaller shot from the accelerator pump, cured his problem immediately.
If the problem is with the piston, you can replace the unit. I would examine the pump for wear, however, and measure the outside diameter and give me a email, as I have new pumps from which to give you some point of reference.
