Old 04-16-2002, 01:29 PM
chopper's Avatar
chopper chopper is offline
Cobra Make, Engine: Previous ERA owner on break
You should be able to just connect the charger to the battery cable connected to the solenoid. However, if that bothers you, just disconnect the negative (ground) terminal from the battery and hook up the positive connection from the charger to the solenoid terminal and the negative connection of the charger to the battery negative terminal. That way, the only circuit being completed is the battery, just as if you removed the battery from the car.
Some folks drink from the fountain of knowledge; others just gargle.
Yesterday's flower children are today's blooming idiots.
