Old 04-16-2002, 02:53 PM
DAVID GAGNARD's Avatar
Ren Man;
Although my car is a 65 Mustang,the mounting should be similar. I went to the local welding shop that also does aluminum welding and got some flat pieces about 1.5 inches wide and up to 10 inches long,mostly out of their scrap pile.. Came home and put the radiator in place with wood blocks and rubber straps and then figured where the flat stips needed to be and the length. Then took the radiator and stips and had them welded to the tanks. One on each side top and bottom,then got some rubber grommet looking things about 1.5 inches in diameter and an inch thick and used between mounting points and radiator tabs. It allows for flex and some movement (very slight) of the radiator....I think if mounted solidly the tanks would eventually tear where welded....This setup has been on my car for 12,000 + miles over the last 4 years or so with no problems what-so-ever....
This is probably one thing that will vary from car to car and depends on the car itself... Griffin sends the radiators with no mounting tabs because they are considered a "universal" radiator....BTW, the Griffin is a very good radiator.....
Hope this helps,I may take some pictures as the radiator is out of the car right now if I could figure how to post them. I'm not to good and stuff like that on the computer....
David
DAVID GAGNARD
