Old 04-16-2002, 03:07 PM
BrianPaul BrianPaul is offline
OOPS! I guess I didn't make myself clear. Fuel is leaking from the exit point at the bottom of the carb where the accel pump shaft meets up with the cam on the throttle plate shaft. I think it may be due to a very old gasket. Both of these carbs have the same problem. My other two do not.
Cal, the measurements are as follows. Piston 15.8mm, Pump shaft is 5.2mm, Brass sleeve in the carb is 5.5mm i.d. I have 55 bypass jets and the floats were calibrated by Enzo.
I hope that this is just a gasket problem. I am going to compare my other non-leakers and see what the differences are.
Matt, When was the SCAT meeting? I would like to go with you. Thanks.
Brian Paul
