Old 11-21-2014, 02:18 PM
Texasdoc's Avatar
Texasdoc Texasdoc is offline
Cobra Make, Engine: Lonestar Classics LS427. Self-built 408W, AFR 195 heads, Performer RPM Intake, Quick Fuel 750, 407rwhp, 479rwtq
For the record, the 470ohm resistor works so far. I haven't burnt out the bulb to test the flow thru the resistor, but with the resistor and bulb, it functions as it should.
I have the new starter that has a built in solenoid. I put the sense wire there. The power wires from the alternator to the starter are each 10 guage with the fusable links. There is a large 2/0 guage wire running from there to the battery.
