Old 11-22-2014, 07:30 AM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Depends on your hand size and body contortion abilities to get into the footwell to see what you are doing under the dash with your hand. But Amp meter comes out easily with one knurled nut on back side of dash thru the front of the dash and it's easier to remove the wires because they are twice as big as the normal wire clips and should be very snug when removed and installed. DISCONNECT THE BATTERY FIRST.
Sure helpful if you guys would add your car numbers to your info displayed in the upper right corner of your posts. 4 different wiring configurations on SPF's defendant on chassis number and helps me help you with other tips and tricks.
SPFWiringDiagrams@Comcast.net
