Old 11-24-2014, 07:15 AM
Cobra #3170 Cobra #3170 is offline
Default Rear ratio
Originally Posted by Anthony View Post
Changing rears to 3.7 may not be enough. Maybe 4.11's-4.30's to get the rpm's up 25%. Also, smaller diameter tire?
what about a truck 2 speed rear?
Maybe sprint car style quick change?
Somebody was making a ford 9" center section interchangeable with the dana. I think he had a machine shop in CA, made remote oil filter brackets for cobra's, and owned csx3020 at one time. If you switch to a 9", swapping out the rear gears I think would be a lot easier.
Thanks for the comments Anthony but putting a higher numerical ratio like a 4.11 is like poking a hornets nest with a stick. That car will bow the tires off
if you give it any kind of advantage. I run a 3.31 to try and control the high wheel torque. I am thinking a 3.54 might be just enough. The package of the rear end is so tight I don't think you could change gears let alone package a quick change without surgery which is a no no on this car.
This is Scotts first run where he used a little too much throttle on the straits and you can hear it getting really loose. The car would be much faster with a 300 HP small block but what fun is that?
[ame]https://www.youtube.com/watch?v=QdAzFgheJBw&index=3&list=UU0CJQuj-tI4J89NccUhpJ1Q[/ame]
