Old 11-24-2014, 03:38 PM
Bernica's Avatar
Bernica Bernica is offline
Senior CC Premier Member
So, with approx 750 miles and a $50k starting bid, who wants to go first on what it will go for? Description provided below...
1965 Shelby Cobra 427 CSX 6000 Series, Excellent Condition, 8 Cylinders, 2 Door, Bucket Seats, Convertible, No Stereo, Spoke Wheels, Make of Tires: Firestone, Model of Tires: Indy 500, Keys: Yes, Front Seats and Carpet Dirty, Front Carpet Good, Front Seat Good, Door Panels Good, Trunk Good, Dash Good, Headliner Good, This vehicle is an authentic Shelby American replica of the 1965 CSX Cobra that was built in 2010. Exterior Color: Navy Blue Metallic, Interior Color: Black, Major Factory Equipment: Shelby Four Wheel Disc Brakes, Shelby Finned Valve Covers, Single Hoop Roll Bar, Wood Steering Wheel, TCI Automatic Transmission, Optima Battery, Shelby Gauges, Leather Upholstery, Simpson Racing Seatbelts, Side Mounted Wind Guards, Aluminum Radiator, Trigo Knock-Off Wheels, Carpeted Trunk, Front & Rear Chrome Bumpers, Steel Braided Lines w/Aluminum Fittings, Electric Cooling Fan, Custom built Shelby 427 V8 FE Stroker Engine-aluminum block, heads, timing cover, flywheel & intake-Dynoformance fuel injection-all steel braided lines-show detailed engine & compartment, Custom TCI Fighter C6 automatic transmission with shift kit-rare automatic model, Independent rear suspension-Blistein shocks & coilcovers-TMS A-arms kit with adjustable front & rear sway bars-Hypercoil springs, There are no known or visible problems with the cooling system-Fluidyne aluminum radiator with dual electric cooling fans, Optima battery-Shelby gauges-MSD electronic ignition & distributor, Shelby 4-wheel discs with dual piston calipers, Dual exhaust with ceramic coated headers & ceramic coated side pipes, Custom built fiberglass body-aluminum inner panels-appears to be minor damage due to the vehicle "bottoming out" on the front frame rails and fiberglass underbody, Very high quality paintwork-custom Navy Blue Metallic with Wimbledon White Lemans Strips-Minor scratches are noted as well as minor damage noted on front underbody, Chrome bumpers front & rear, Black leather upholstery-wood steering wheel-Simpson Racing Harnesses, No top or tonneau cover, the weather stripping is soft & pliable and have no noted blemishes, 6-pin Trigo knock off wheels with safety wires-no blemishes, Tires show no wear or deterioration-Firestone Firehawk Indy 500 tires-235/60R15 front & 295/50R15, This vehicle was manufactured by an authorized Shelby builder and a MSO issued by Shelby, the vehicle shows minimal wear with two blemished noted, the exterior paint shows minor scratches and dings
